#99411 - 14/06/2002 02:19 eternal [ir_translate] error
miguelon
Please help
First of all, i'm sorry: perhaps this solution it's already posted but I've read all the FAQs and the forum for 2 hours and i didn't find it.
I've modify my config.ini file with the translations for my pioneerSR80 and i forgot find&change the CR/LF simbols in UltraEdit, so i put a corrupted config.ini in my empeg (arggghh!!! i'm idiot!!!!)
The result is that my empeg doesn't respond. It claims an eternal ir_translate error.
With Hyperterminal i can't press q so fast to stop the boot process and get shell.
I've tried upgrading again with soft 2.00beta11 and Hijack, but it's the same.
- upgrading soft 2.00beta11: the upgrade runs ok with emplode but the player boots and doesn'¡t respond, only show de logo.
--------after upgrade 2.00beta11 over previos hijack---------
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 30102748)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:b
c
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
player(7): memory violation at pc=0x020d79a4, lr=0x020d7954 (bad address=0x0b14a
c91, code 2)
pc : [<020d79a4>] lr : [<020d7954>]
sp : bffffd84 ip : bffffda4 fp : bffffda0
r10: 02146b34 r9 : 02146da0 r8 : 0214ac98
r7 : 0b14ac8d r6 : 02145fa8 r5 : 0214ac89 r4 : 09000004
r3 : 00000000 r2 : 09000004 r1 : 0214ac89 r0 : 02145fa8
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F7517D Table: C0F7517D DAC: 00000015
Function entered at [<020d7984>] from [<020d7954>]
r7 = 0214AC91 r6 = 0214BFC8 r5 = 0214AC89 r4 = 02145FA8
Function entered at [<020d78ac>] from [<020bf1d8>]
r5 = BFFFFE98 r4 = 00000001
Function entered at [<020bf154>] from [<0209c678>]
r10 = BFFFFE80 r9 = 02146DA0 r8 = 0214AC98 r7 = 0214AC91
r6 = 0214BFC8 r5 = BFFFFE98 r4 = 00000001
Function entered at [<0209c084>] from [<02072084>]
r10 = 02030E64 r9 = 00000000 r8 = 0210C4F8 r7 = 00000000
r6 = 02146CF0 r5 = 00000000 r4 = 02146D1C
Function entered at [<02071fac>] from [<0207b0b8>]
r6 = 020000C0 r5 = BFFFFF64 r4 = 02146AF4
Function entered at [<0207b0a0>] from [<02109444>]
Function entered at [<02109420>] from [<020000d4>]
r4 = 00000001
Function entered at [<020000c0>] from [<020c3330>]
Function entered at [<020c326c>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
player(8): memory violation at pc=0x020d79a4, lr=0x020d7954 (bad address=0x0b14a
c91, code 2)
r4 = 00000001
- after uploading hijack (with logoeditor) i get again the same ir_translate config error.
------- hijack over 2.00beta1---------------
e000 v1.04
Copying kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v270 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Thu May 30 11:17:16 EDT 2002
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
empeg state support initialised 0089/88c1 (save to d0005180).
c
Partition check:
Freeing unused kernel memory: 4k initqempeg init 0.8
Mounting proc
player
q
[ir_translate] ERROR: : "AD520A.B"
[ir_translate] ERROR: : "AD520B.A"
khttpd: listening on port 80
kftpd: listening on port 21
q
Starting player
Starting player
Starting player
What can i do?
Please help, I've to go in a 6 hours trip in 3 hours from now and i'm desperate.
Thanks, folks.
#99412 - 14/06/2002 03:13 Re: eternal [ir_translate] error [Re: miguelon]
miguelon
Ok, finally i've find it!!!!
Not pressing 'q' in boot sequence in Hyperterminal!!!
I tried to press Ctrl-C and it works! i've got the shell!!!
Yasta.
Gracias,tios
Thanks,folks
#99413 - 14/06/2002 05:48 Re: eternal [ir_translate] error [Re: miguelon]
FTP should still work too, so you can FTP the old config.ini to another machine, FIX it, and then FTP it back again.
cheers
